Poll - Who DIY's their valve adjustment??
I think its a DIY if you have already mastered the oil changes, the spark plug changing, and exhaust removal. I was a bit nervous I would screw something up... but it seems to have gone alright using the feeler gauge to check the clearances. I only had 2 or 3 clearances that needed adjustment. I used instructions from the books and one of these buliten boards since I had never done it on a 911 before. ( I had checked and adjusted valves on motorcyles before.)
i did it at a relaxed pace...started Saturday morning and finished Sunday night. I went slow and deliberate and also installed 2 race seats at the same time, and had to modify both seat mounting brackets.
It was a bit enjoyable..... but that was about a year ago... so maybe its just that time makes you forget the PITA parts.
Ed
'02 C2 Cab
Ed
'02 C2 Cab
Professor of Pending Projects
I do all the work myself... except if I have to drop and open the engine... still afraid of doing that with the 964 (did so with the 951)...
I also keep the cover in the engine bay off... makes it easier to keep it clean and work on the car. I think this is something car nuts should do. Makes you one with your car.
Hey Donger! Looks like all went well with your PPI and you closed on that white C2 Cab. Congrats. I had a car PPIed yesterday and today. Looking seriously at another. Hopefully pull the trigger on something very soon.
I like to think of myself not so much as a tightwad but thrifty - it sounds better - so i plan on taking a crack at DIYing my valves, that is if i find some to buy.
jg
jg
Dr. Jupe,
From the looks of your avatar, I'd say you may have tightened something a little too much
Green,
Hope all goes well with your PPI. Make sure you get a good PPI, I am afraid the PPI I got was a little weak, I wasn't terribly impressed with them, but I wanted the car so bad I didn't get a second opinion. I think all they really did was make sure all the bulbs worked correctly. So far so good though.
Regards,
The Donger
Green,
Regards,
The Donger
Garrett check out this link for more "shrunk exotics"
http://www.6speedonline.com/forums/s...5&pagenumber=1
