Euro RS Hood Support
Technical Guru
Are you sure about that? When I checked on 10/21/2004, 911-511-010-30-GRV was available from Germany (they had plenty in stock) for $1950USD. Maybe I have the wrong part number for the aluminum RS front hood?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Damn, now I have to go and buy one, just in case. It was better when I thought they were no longer available.
Technical Specialist
Lifetime Member
Lifetime Member
While not original, I got an email from Seine Systems this morning that they will be offering a carbon hood brace, similar to the RS brace in function, with no drilling or rivets needed. Around $40, as I recall. It's not on their website yet, and I discarded the email, however, if you send them a note they have some pictures that show how it works. (no affiliation)
You might want to verify that these are not the 993 AL hoods - from what i have heard and seen - these will be the soft crease 993 AL RS hoods. I recall that they combined the part numbers a while back since the fit is the same.
just a thought....they fit exactly the same and i do not believe they are drilled for the windshield washer nozzles as on the 993 Street version.
"While not original, I got an email from Seine Systems this morning"
Hi Bill,
Not sure how to frame this answer w/o appearing too commercial. I haven't test-fitted one on a 964 yet, but they fit on 911s and 993s and are now available.
Although not "factory", it appears to be substantially less $$ than the factory RS kit and should require no drilling or cutting to install. I can also guarantee that it's lighter at <3.5 oz. More info here.
Sherwood
Hi Bill,
Sherwood
