964 Forum 1989-1994
Humpty Dumpty Interior Pictures
Old 01-03-2005, 06:51 PM
  #31
Robert Linton
Robert Linton's Avatar
As I presume you are asking about cooling to the front brakes (the rear brakes have their own cooling system), let me describe it (other than, of course, designing the lithium aluminum calipers themselves for most efficient cooling).
The system starts with the specially made and particularly large oriface front mounted ducts pictured above, the presence of which required modifications to the inner part of the front bumper. In this regard, also note the screens bonded to the ducts to prevent debris from entering the system.
In turn, air is fed into specially shaped carbon fiber catch ducts mounted to the left and right side oil coolers (or right side oil cooler and left side a/c condenser). The shape and angularity of the catch ducts were designed to simultaneously permit both a maximum amount of air to be harvested and to allow for maximum wheel clearance (original factory and other ducts I have seen limit steering as the wheel hits the duct). In turn, a large diameter flexible hose is connected to each catch duct that, in turn, is connected to a carbon fiber duct mounted to the cast titanium upright. Such duct is designed to most efficiently direct air into the brake system.
P.S. The carbon fiber rear swing arms have a dual forced air carbon fiber ducting system to cool both the rear brake system and the outer (wheel side) CV joints (and the carbon fiber undertray forces air to cool the transmission and the inner CV's).
Old 01-03-2005, 07:15 PM
  #32
John Boggiano
Lifetime Member
John Boggiano's Avatar
Art meets engineering.
Again.
Old 01-03-2005, 07:26 PM
  #33
garrett376
garrett376's Avatar
Wow! I like how your oil fittings match the exterior color!
Those suspension pieces are amazing!
Old 01-03-2005, 07:31 PM
  #34
Robert Linton
Thank you.
Old 01-03-2005, 07:48 PM
  #35
Robert Linton
Two pictures of the swing arm showing the dual carbon fiber interior ducts and the outlet for brake system cooling.
Old 01-03-2005, 10:59 PM
  #36
bhensarl
Jarhead
bhensarl's Avatar
I knew there must be some sort of exotic contraption hidden behind those vents! Wonderful job. Especially impressive, in my opinion, is that you're venting air to both the brakes and the oil cooler/ a/c condensor. Awesome pics.
Brian
Old 01-04-2005, 05:28 AM
  #37
warmfuzzies
warmfuzzies's Avatar
Robert,
Will you ever be making any pictorial history of the parts made for the car? Other than here on Rennlist of course........
If nothing else they are beautiful pieces of art work.
Kevin
Old 01-04-2005, 09:50 AM
  #38
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Originally Posted by warmfuzzies
Robert,
Kevin
I agree... this calls for a book...
Quick Reply: Humpty Dumpty Interior Pictures
