Heated Seats
No heat in drivers seat. Power is getting to switch. Any thoughts? Should both the seat and back have heat? Passenger side is great (wife smilling).
Sense you did check the voltage (12volts) going to the switch and determined that there was power coming out of the switch (12volts), you should now disconnect the heater from the switch. Attach your DVOM to the two connections on the heater and check the resistance. If there is no resistance, then the heater is no good and should be replaced.
As for the heater in the back of the seat, mine does, but I am sure that it will differ from the opption list on vehicles, as does the seats themselves.
Duncan
Duncan
