Rear Brake Rotors - Strange Wear pattern
Couple months back I finished changing out the brakes on my 90 C2. Put Big Reds on the front, 993 Cailpers on the rear, Cross drilled rotors all round - ...well almost round. See, I think that's my problem.
Over the weekend, I changed oil and trans fluid. Had the rear wheels off. The rear rotors have a spot worn into the EGDE of the rotor. Appears on both sides of the car. The passenger side appears to be about 3-4 inches long and about 1/16 to 1/8th deep. the driver side only about 2-3 inches and 1/16th or less.
I am totally clueless as to how this got there. It would almost appear to be grind marks that may have been used to balance the rotors, but I surely would have noticed this when I installed them... I think?
I'm totally stumped and feeling clueless... The brakes feel fine, and there have been no unusual noises. So I can't fathom how the grinding occured. For it to have been one spot as opposed to all around the outer edge of the rotor - the rotor would have to have been horribly out of round.
I guess my questions for the list.... has anyone else seen this? Are rotors balanced by removing metal-ie. grinding, from the mfg? Could something from the caliper gouge a rotor to 1/6th inch depth for without making some noise?
Man..... I'm confused. Car still runs great and stops on a dime, BUT....
Marshall McCray
1990 964 C2
1987 944S
Marshall McCray
1990 964 C2
1987 944S
Technical Specialist
Lifetime Member
Lifetime Member
Marshall,
If it looks like a piece was planed off the outside edge, you're correct, that's was done by the OEM rotor manufacturer to balance the rotor.
Bill
Thanks a whole lot. I've really been pulling my hair out over this one. I just can't believe I didn't notice it when I installed them. There simply isn't any other reasonable explanation. Thanks for putting my mind at ease on this one.
Marshall McCray
1990 C2
1987 944S
Marshall McCray
1990 C2
1987 944S
