964 Forum 1989-1994
Anyone with Turbo wheels on 964?
Old 10-12-2004, 03:53 PM
Computamedic
Computamedic's Avatar
Paul,
Yes... and no. You're right in that it IS a Strosek design but mine is a fibre glass kit manufactured by Pro-9 in the UK (www.pro-9.co.uk). I suspect the quality is not up to Strosek's originals - but, hey, it looks good!!
Regards
Dave
Old 10-13-2004, 06:19 AM
Robert CH
Cruisin'
Robert CH's Avatar
NTTY,
No I don't live in the french part. I live in the germen part near Zürich. My girlfrend lives in Biel. In this case the "Röschtigrabe" (swiss guys know what I mean) is not a problem for me. Of couse we could share some Bears....
Kind regards,
Robert
Old 10-13-2004, 10:58 AM
Arjan B.
Arjan B.'s Avatar
I would go for the original 964 turbo wheels, they fit more nicely.... But you know, taste, a big problem sometimes.
Old 10-13-2004, 05:13 PM
bron964
bron964's Avatar
how about these?
Old 10-13-2004, 05:44 PM
dove
dove's Avatar
Originally Posted by Computamedic
Paul,
Regards
Dave
Dave heres a few pics of a car I once owned,its a Strosek 964 cab built at the Strosek factory.Mods include replaced front wings, front pu,mirrors,rear wheel arch extensions plus a few mods to the interior.
Cheers
Paul
Old 12-11-2004, 06:43 PM
Pesty
Pesty's Avatar
Hi Guys,
Sorry to drag up an old subject. My car has 18inch wheels on. Now I realise that Porsche do not aprove of this and that there may be a problem etc etc. But I was going to maybe look around for some 17 wheels when my current tyres were worn. wasnt too concerened after reading up on here and other places.
Looking around the car today I noticed on the passenger side tyre I noticed a grove on the outer edge.
I'm guessing that its the wing/wheel arch thats caused it, probably going over speed bumps I would imagine.
Any ideas on possible causes ? whats my next step. I realise its hard to diagnose from a distance.
also and this may have something to do with it teh left hand front tyre appears closer to the bumper than the right. only by a few mm but the gap is definately smaller.
Old 12-13-2004, 04:06 AM
Christer
Christer's Avatar
Pesty
We need to know wheel widths, offsets and size of tyre you are running.
Old 12-13-2004, 12:08 PM
Pesty
Pesty's Avatar
Tyres
265-35-18 Rear
225-40-18 Front
Dont know how to find the width and offset. Just had a look at the wheels and cant see any obvious markings.
Sorry I realise this isnt too helpful.
Old 12-13-2004, 12:13 PM
Christer
Christer's Avatar
Hi Pesty
Well its not the tyres that are causing a problem I would have thought. The width and offset of the wheels are therefore totally necessary to help you out. Can you see any spacers (or shims) fitted? Without this, you might as well just ask your Porsche Specialist for help because it will be impossible to gauge what the problem is. My guess would be that the wheels are off a Turbo model of some sort so the offset is too low and pushes your wheel out too far....thatis you don't have spacers of course...
Re markings, can you see something like 8J near your valve stem on the wheels? If so, the other number might be the offset......if there are no markings then they might be aftermarket and then all bets are off!
Old 12-13-2004, 12:25 PM
Pesty
Pesty's Avatar
Thanks Christer,
Just had another look. no markings near the valve. Pretty sure there are no spacers but the wheels do fill out the wheel arch right to the edge. So Maybe that is the problem.
I will ring up a specialist. I think 9m are around 70 miles away and Im off now till christmas so If they recomend driving up so they can have a look ill do that.
they are the only independants I know of that arnt too far away and they have a pretty good reputation so Ill try them .
Thanks again for your help.
Old 12-13-2004, 12:40 PM
Christer
Christer's Avatar
Yes, I have had alittle bit of work done by 9M myself. They should be able to help.
Old 12-13-2004, 05:47 PM
MacFever
MacFever's Avatar
With 18" GT3
Old 12-13-2004, 11:53 PM
9XI
9XI's Avatar
I just replaced the 18" turbo twists on my car with the 17" wheels that belong on it (except that I went with 9s in the back instead of the stock 8s). Tramlining is gone. Wrestling the car over rough roads is a thing of the past. No more push in corners. The car is light and balanced now.
With the added tire sidewal height, I'd feel comfortable with stiffer springs (I have M030s).
Given the choice between 18" wheels and regular springs or 17" wheels and stiffer springs, I opt for the 17" set up.
I'll give more reports as I work through the suspension parts. But for now, I am very happy to have gone back to 17s.
Quick Reply: Anyone with Turbo wheels on 964?
