1992 C2 Cab. Conv. Question...
Under the dash - it's attached to the sheetmetal under the gauges - it's next to the central informer.... boy, I bet that helps!!! If you're sitting in the car, it is almost directly above your left shin... tucked up WAY under there.
let me see if I've got a pic....
Ok, you need to use you imagination here! You'll need to remove the central informer (silver box) to get to it. You can see how it's tucked under there. Hope these help!
