Humming fuel pump solved, costs....50 cents
Today I had the idea to solve the humming sound of the fuel pump. I was thinking how to do this and what the cause of the humming was. I suspecter metal to metal contact from the pump, and I found the following cause.....
The bolts go thru a rubber and inside the rubber is a metal peice to prevent over tightning the installation of the pump. This is metal to metal contact to the bracket who is welded to the body. I removed the metal parts and put some rubber [fuel hose] pieces in stead of those. Now we have no metal to metal contact which brings sound to the body. It works........
Great tip Arjan! I might just do this since my fuel pump buzzes too. But I remember reading somewhere that a buzzing (loud) fuel pump is abnormal and may be first sign of failure. What do you think?
My pump does buzz still a bit, but the big buzz is gone. Since I bought my car in 2001 the pump is buzzing, not more not less. I think it's wear, yes, and I think I will replace it sometime, but you know, the price of it........ it's not cheap
Yeah, I guess that one of the connecting steel tubes or something similar could be contacting the body and thus create the noise. Could be a good idea to jam a piece of rubber insulation in between. Seems like I will have to peek under the front hood this weekend.
