Flapper motor servo replacement
I've got a bad fresh air flapper servo motor........ list is $150, and i'm guessing the little motor in the servo box could be found for a lot less..... I just don't know where.....
Has anyone found a replacement motor that will work? (I've got the fault code from the Hammer, and after removing the servo box, and testing with 12 volts, i've got a little movement from the motor, and sparks, and smoke.... )
Thanks for any info,
-Eric
NER/PCA
90 C2
-Eric
NER/PCA
90 C2
