Will need heat soon
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Just replaced the blower motor and fuse. No heat in cockpit although all fans work. Rear blower only goes on at shutdown if you leave the key on. Does anyone have any suggestions. 91 c2 in Ottawa Canada. Just purchased this spring. Adrian and his book helped out with some suggestions to get my engine running properly now I need to prepare for the fall weather. thanks Doug
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
It sounds like the mixing flap servos, the climate control unit, or a loose connector. All are trouble prone. I don't know how to post the link, but if you do a search, thie subjects have been covered in detail. The mixing flaps are relatively easy to fix. The climate control unit is expensive, so be sure to check everything else first. The climate control unit can be fixed if you can troubleshoot and are handy with a soldering iron. Good luck. You will need your heat on Ottawa.
