CupCar Help
I am looking for some help in aquiring a set of front Carrera RS a-arms and a set of Carrera RS rear guide arms for a 93 euro Cup Car. any info or direction would greatly be appreciated. Also any idea of replacement bushings would be of help. Trying to stay GTC-1 legal.
Pat
Pat
Technical Specialist
Lifetime Member
Lifetime Member
The RS a-arms and rear swing arms should still be available from Porsche, do you need part numbers?
ERP makes replacement monoball bushings for the front and rear, as well as a monoball swing plate which allows greater camber adjustments. I've installed these, and they make quite a difference.
Aren't those particular components on a US spec Carrera RS America different than the euro Carrera RS street model and the racing 964 Carrera Cup car? Thus the trouble in finding them for the Cup car?
Bill;
If you can supply parts numbers associated with a specific car model that would help a lot.
Bill;
Bush (front) 964 343 182 70
rear control arm link - left 964 331 060 80 ( 964 331 059 80 - right)
front control arm (Carrera RS - NOT RSA)
964 341 017 80 (left)
964 341 018 80 (right)
Guide arm (Carrera RS)
964 331 021 70 (left) 022 (right)
bearing
999 053 042 05
not sure if that is what you were looking for - these parts can be ordered via porsche motorsports NA
bearing
999 053 042 05
Lifetime Member
Lifetime Member
Note Carrera RS parts can be ordered via any Porsche dealer who will order from Europe. Although I've been surprised that some Carrera RS parts are stocked in Atlanta. There are some discounting Porsche dealers who will order from Europe, if you need a lead, pm or email me.
Technical Guru
I recently had all these priced out at a discounting Porsche dealership; the number in parentheses is the quantity required per vehicle, next number is pricing and the number following is the # available in the USA, BO - Back Order take 4-6 weeks unless you pay for Porsche's expedited shipping from Germany, FBO - factory back-order = find someone else to buy from; If there is no number following the price that means they have plenty!
Front Suspension
964 341 017 80 track control arm /L (1) $350.11 bo
964 341 018 80 track control arm /R (1) $350.11 bo
964 343 041 80 shock absorber strut /L (1) $271.42 bo
964 343 042 80 shock absorber strut /R (1) $271.42 bo
964 343 018 82 supporting mount (2) $280.23 2 in USA
964 343 503 00 concave washer (2) $4.97
964 343 502 00 adjusting nut (2) $10.97 4 in USA
964 341 511 80 gasket (2) $3.86 2 in USA
964 343 301 80 rubber stop (2) $16.02 bo
964 343 505 00 boot (2) $6.41
964 343 531 80 504 coil spring (marked yellow) (1) $158.86 bo
999 085 001 02 socket head nut (8) or (1) $2.98
964 333 469 80 screw (2) $30.58 bo
964 343 182 81 spacer sleeve (2) $14.73
964 343 182 82 spacer sleeve (2) $14.69 bo
964 343 186 80 sealing cap (2) $1.64 bo
964 343 188 80 retaining spring (2) $3.94
999 591 931 40 clip (2) $0.28
rear suspension
964 333 057 80 vibration damper (2) $203.26 2 in Germany
964 333 523 81 concave washer (2) $30.00
964 333 105 80 additional spring (2) $13.41
964 333 531 80 coil spring (1) $158.86
964 333 059 82 suspension strut mounting (2) $188.77 fbo
964 343 469 80 screw (2) $30.50 2 in USA
964 333 466 83 spacer sleeve (2) $4.38 bo
964 333 466 84 spacer sleeve (2) $8.28 bo
Front Suspension
rear suspension
