chip advice?
chip advice?
hi 964ers
been offered a chip (for £100)... a question or two to the slightly less mechanically challenged amongst us... how much does the chip improve BHP / performance?... are there different types? ...will it cause any damage? is it a big job to install? ....the old girl is a '90 C2 (totally standard) and pretty **** hot off the mark as she is, but tends to splutter a little in high revs (especially 3rd & 4th gear) which can be a little off-putting at times...
any help would be great
albi
derbyshire
england
albi
derbyshire
england
Depends where the chip is from. Is it an off the shelf item (eg Superchips) or was it mapped specifically for a car?
Easy enough to install - ECU is under passenger seat - and shouldn't do any harm. You won't see much change in BHP but the engine's characteristics may alter. It certainly won't help your spluttering problem - that could be a number of things, possibly dirty injectors.
I'd try it before you buy.
Cheers
Cheers
chip
Cheers
Cheers
cheers
albi
Mine changed the driving characteristics, ie. more torque lower in the rev range, better driveability.
Although, I do feel an increase in power at the upper limit.
As Phil said, try before you buy.
Colin
Colin
Technical Guru
Originally Posted by albi964
sorry to be a pain... but if it doesn't improve BHP what is it supposed to do?
Every time someone dyno tests an off-the-shelf chip they end up with pretty close to a zero % gain. The difference between stock and off-the-shelf is always less than the error rate for the dyno. Unless your having a chip custom programmed for your car while it is on a dyno don't bother.
