Shark's Fin
Hi All!
Been awhile since my last post. Here goes it. The Shark's Fin between the door sill and rear wheels. Can the clips which hold this piece be replaced? Was told by the mechanic, they could not and would have to order new fins.
Right now, they are held in place with JB Weld. Might as well replace the rubbers since there is significant "shrinkage"
THANKS VERY MUCH!
THANKS VERY MUCH!
Yes the clips can be replaced. I believe the clips are same as the rocker panels:
999 591 916 40 – clips
999 498 008 40 – plastic nuts
999 702 160 40 - grommet
Cheers,
Cheers,
Super Guru
Originally Posted by Sailswish
Thanks Kahdmus for going the extra mile and listing the part #'s !!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Hi,
Actually in the official Porche manual, they suggest repairing the clips with epoxy cmpd just like JB Weld. I simply rewelded mine also with JB Weld...works just fine...but I did replace the shruken rubber stuff.
John
Texas
John
Texas
IMHO - these are really pretty cheap and they always break when you take them off, well most of the time for most people and always for me
. so replacement is the safest bet. I went the JB weld route once and lost a Fin on the highway (it seperated and then pulled totally off.
my 2 cents.
Great to have the part numbers handy - they are normally in stock at the dealer
my 2 cents.
Kahdmus,
You don't know the part numbers for the black rubber strips that sit between the plastic outer sill and the body work do you? mine have shrunk as well.
Sailswich - did you replace your rubber strips in the end?
Cheers
Alister
Cheers
Alister
Let me check my reciept...
...EDIT: Part numbers as follows:
96455929301 for the main piece and
96455929501 for the piece that goes over the shark fin.
There are some hints, tips and pics on my site:
www.porsche964.co.uk ->technical ->body
Cheers,
John
Cheers,
John
Originally Posted by Kahdmus
John, I think I sent you the part numbers when I had them. I didnt think to check your site (DOH!) Did you ever get to adding them?
Thanks all,
J
Originally Posted by John Miles
Yep, I have them. Just need to update. You guys send me so much stuff.......I need a week!
Thanks all,
J
Thanks all,
J
BTW, can we expect a 2004 photo comp?
