air bag light/seat belt light
Going on Saturday to get air bag light cleared with the hammer, replaced removed bulbs taken out so I wouldn't have to look at the lights. The seat belt light is also on. Will that be cleared when the air bag light is cleared or do I have a problem with the seat belt warning light system.
Adrian's book says the seat belt light comes on with the airbag light. On my 92 C2, I had only the airbag light and seat belt light only if I did not buckle up.
Be sure the shop gives you the error that caused the light. According to the receipts, my PO had the airbag light reset several times, but they did not fix the underlying problem. I got the light just a couple of months after buying the car. It did not come back after I cleaned the crash sensor contacts (a 5-minute job).
Good luck
Good luck
I forgot to reconnect the crash sensor after replacing the front blower fan,that triggered it. I finally found someone local with a hammer and I forgot if the seat belt went on at the same time. You cleared it up for me.
Many Thanks
Many Thanks
