will 96 mirrors fit on 964
I believe the Aero's are spec'd for 993 and 964. Read a description on a parts site to make sure, but Im sure when I got mine it stated for 993, 964 or 911.
They will fit. The wiring may be different though if power. The rubber gasket is also different. Since the bases are shaped differently, there may be a subtle difference in paint color when you remove the old gasket/mirror.
Originally posted by Ruairidh
As Adsc4s says - you will need the proper base and gasket. There are lots of posts on the way to match the wires.
![](http://forums.rennlist.com/upload/mirror_copy2.jpg)
