964 Forum 1989-1994
Idle Settling Issue
Old Jan 11, 2025 | 11:03 AM
cabbazio's Avatar
cabbazio
Originally Posted by Foxman
I also run with web cams in my 964, along with a LWF. Both of these can wreak havoc on idle stabilization. Steve Wong makes a customized chip that largely solved the problem for me. I would reach out to Steve, but you should first determine whether or not you have a LWF.
Cleaning out the ISV is also good advice, and worth the time and effort.
Thanks! Cleaning the ISV was the first step I took. It’s clean and tested as operational so I think the ISV is fine.
Working on confirming whether the car has a LWF so I can try a new chip.
Old Jan 12, 2025 | 09:10 AM
LM964's Avatar
LM964
Aye, once I had the RS clutch/flywheel fitted it did require a remapped chip to manage the (more free running) rev range.
