Lowering springs?
Do the H&R springs for the 965 turbo fit on a regular 964 -90? Are they matching the bilstein sport dampers? And finally, was the stock turbo 5mm lower than the C2/C4? Thank´s for any reply!
Regards
Steffo
Regards
Steffo
Whats the part number? I recently bought H&R springs for 993 turbo, part # 964.343.531.12 , which I'm told will fit. They will be installed next week, we see what happens. Full write up on the 964 boartd..OF COURSE!!
I put 965 springs on my 964 and it did not make a huge difference in the ride height. However it did lower it alittle and seemed to stiffen up the suspension noticebly. The H&R springs will probably lower and stiffen the car more than the stock 965 springs. Oh I did not change the shocks at that time but I have done so sense. GOOD LUCK!
I have installed the H&R 965 springs on my 964. they lower the car approx 1 1/2" . You can use either the Bilstein struts or Koni's. The H&R turbo springs are supposed to have a higher spring rate than the H&R 964 springs.
I believe that the stock US turbo springs(M030) are the same height as the standard 964. The ROW turbo springs (M030) are slightly shorter.
Thank´s guys! I've heard that the H&R 965 springs make an improvement in handling compared to the H&R 964 springs.
Colin: How is the ride comfort in cruising speeds (60-80 mph)?
Steffo
Steffo
I find the H&R's are actually smoother than the stock springs. Remember that the stock springs are a linear rate and the H&R's are variable rate.
The H&R's smooth out the bumps better and once the springs compress in a turn, the car feels like it is on rails.
Colin
Colin
H&R 965 springs with bilstein HDs are a great match for street and some track use. But ever since I got bitten by the DE bug I felt I could use more spring rates, lots more.
Gosh I sounded just like Jeff Curtis.![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Does anyone know if the H&R 965 springs will fit at the rear on a -90 C2? The upper damper fittings where changed on the -91 and on C2/C4 and I suppose the 965 fittings are the same as the later C2/C4 model's.
Steffo
Steffo
As colin stated - it is the struts you need to worry about, I just ordered mine and had to specify 89-90. The springs remain the same
My spring part#'s are in fact: 29 598 VA and 29 598 HA. These actually are for the 993 TT. Spring rates should be a good match (thanks to Peter C who looked them up) 230-265 (Front) and 280-320 (Rear). I just pray they will fit on the Bilstein struts (arriving tomorrow). <crosses fingers and starts praying>
Hey Guys
Since many of you have lowered I'm wondering have you had any issues with speed bumps or anything else that may cause the car to hit underneath. I like the fact that the ride comfort hasn't suffered.
Your replies are welcome
Bill
90C2
Bill
90C2
This is how I wrote up the experience at this page:
The 300km trip to the Ring told me that the Red springs are quite a bit firmer than the Greens. This is very noticeable when cornering: the car stays much flatter and turns in better. Naturally, squat and dive are less than with the Greens. Again there's no problem bottoming out when going through the compression at Fuchsröhre or when going round the Karussell. Even though the Red springs are quite firm, they don't rattle teeth unless you drive over a sharp ridge that's perpendicular to your direction. Road holding has improved a lot. The ride height is the same as with the Greens.
Cheers,
JW
