964 Forum 1989-1994
Car stalls when coming to stop
Old 08-12-2013, 05:08 PM
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
That is the Idle microswitch at the end of the throttle linkage.
Old 08-12-2013, 05:15 PM
crg53
crg53's Avatar
The idle and WOT microswitches. They come as a unit.
Old 08-12-2013, 09:05 PM
GermanCarSpecialists
Former Vendor
GermanCarSpecialists's Avatar
First thing to isolate. Is it doing it when the air condition is turned on?
Try to duplicate it with the air-con off, and see if it happens, or if it happens as severe/frequent.
Based on that I can type down suggestions.
Old 08-13-2013, 04:21 AM
Mr Bacchus
Mr Bacchus's Avatar
As others have suggested it could be ISV related, is the idle stable?
When I bought my car it had a very lumpy idle and frequent cutting out, the car had too much oil and that was getting into the inlet and was contaminating the ISV. I sucked out some oil, maybe 200ml, cleaned the ISV (30 minutes) and the car has been great since.
Steve
Old 08-13-2013, 04:26 AM
sml
sml's Avatar
I had incremental idle improvements from ...
- new or clean ISV
- Caltex Techron fuel treatment
- checking intake for leaks
- DME chip
The real solution ended up being ...
- System adaptation with Bosch Hammer
Old 02-05-2014, 10:30 PM
montys964
montys964's Avatar
Sxton04 -where did you find a 964 airflow meter for $450? everything I have seen is over $1000.
Quick Reply: Car stalls when coming to stop
