Adrian, Randall .. Help :)
I am converting my AC from R12 to R134. It was leaking and contaminated so I figured I would change the expansion valve (leaking) and dryer and convert all at the same time. At this moment I have the expansion valve and dryer removed and the lines to the compressor removed. I intend to blow the out with compressed air (BTW I did have an ac shop evacuate what was left of my freon).
My question is this; Do I have to change the type of oil in the compressor? I have been told that I should. But I though I read somewhere where Adrian said that Porsche aticipated the change to R134 and that was not necessary.
I really hat to remove the compressor as it seems it will be almost impossible to get the nuts back on (on the back 2 bolts)
Please provide guidance![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks,
Lon
Thanks,
Lon
If the system is contaminated (see any dark oil?), it will need to be flushed. There is a commercial product for this purpose. I used brake cleaner with good results before I found the commercial flush. I think they are the same solvent. Flushing is a good idea even if you have the compatible oil. It lets you get the oil charge exactly right, because you start at zero oil in the system.
I have connected service hoses to a propane tank to give the system a final flush and blow out. I charge with the tank inverted to get liquid into the lines. It boils all the way out, and leaves the system nice and clean. Please use lots of ventilation and no smoking!
Good luck
Good luck
Can you elobarate on what you mean by using Propane?
Are you filling the system with propane first, then evacuating?
What do you mean by it boils all the way out?
I'm assuming you put the propane in before an oil charge?
I guess I'm looking for the most cost-effective( read cheapest) way to flush out an old system.
Thanks,
Colin
Thanks,
Colin
Thanks for the replys guys. I dont see any oil at the moment, but so far I have only loosened the hi and lo pressure lines. I am not wanting to remove the compressor unless it is absolutley mandantory, I cant believe Porsche used nuts on the bottom instead of threading. But I suppose when they built the car it was easy to reach at that stage.
Lon
Lon
Good luck
thanks, I'll give the propane a try.
I'm doing the system of my Ford work van and I'm only trying to get about 2 years out of it. The receiver/drier dessicant bag blew apart and has sent the dessicant everywhere. Luckily it has clogged at the orifice. I am going to flush the lines, replace the accumulator and change over to R134.
Right now I just have a very oily, sooty mess and am looking for all ways to clean the system.
Thanks for the info.
Colin
Colin
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Lon,
I am a little confused with your post. Conversion to R-134 from R-12 requires the oil used in the system to be changed. This is 100% correct.
The receiver dryer has to be replaced as well. This is all in the book.
The entire system when re-assembled has be to evacuated again and all the remnants of the R-12 and lubricant removed. The system is then recharged with R-134 and the new oil which is mixed together before it is added to the system. There is no oil resevoir in the compressor if that is what you are asking.
You must do this properly otherwise all your efforts are in vain.
Do not forget to replace the mounting bolt on the expansion valve to the new long one.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
Thanks for the replys .
So , other than the R134, the compresser doesnt have any PAG or Ester oil?
On, the nut issue, I looked at mine again just to be sure and without removing the fan and shroud I absolutley cant even see the nut in the back , closest to the shroud.
But if there is no oil to change then I guess there is no worries.
93 models had R134
Lon
93 models had R134
Lon
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Lon,
Make sure you get R-134a oil. R-134a is not compatible with the oil used for R-12.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
Lifetime Member
Lifetime Member
Lon - If you can't even see that nut, I think it's been replaced with a smaller than standard one.
I think it should be a large, square one. I manage to wedge mine with a socket wrench handle, when I need to make an adjustment. The others had enough 'bite' to not need holding, fortunately.
Thanks for all the help guys. This project is all wrapped up and blowing cold at 49 degrees.
Here is a summary of my DIY; I replaced the expansion valve (man what a headache, would have been easier with gas tank removed or tiny tiny hands) and reciever/dryer , O-rings, R134 service valves. Then I took it to a local shop and had them use vaccum tp purge th compressor of remaining oil and replace it with Ester, then Charge the system with R134.
I appreciate the help. the next project starts next week, Clear lenses and bumperettes.
Thanks again,
Lon
Thanks again,
Lon
ulfpc- I have a 1993 964 with the 134a. I believe that's the first year....maybe some 1992's??? There should be a tag somewhere on your compressor/engine compartment that says which kind of freon your system is.
