964 Tie Rod Help
964 Tie Rod Help
Needing to replace the steering rack boots on my Carrera 4. Trying to remove tie rod from steering arm on the hub. Unbolted and taper end slipped partially out. Any tips on how to fully remove and clear the bottom of the strut? Thanks.
Hope the thread below can help? Post #4 tells how to remove from steering arm
https://rennlist.com/forums/diy-964-...p-install.html
964Luftballoon (08-30-2024)
