964 Forum 1989-1994
Dead 964
Old Jul 25, 2024 | 12:15 PM
0luke1's Avatar
0luke1
From: South Florida and Jersey shore (Monmouth County,)
Default Dead 964
Could use some advice.
No power on any ignition switch settings. Battery measures 12.48V. Ignition switch?
Old Jul 25, 2024 | 02:01 PM
No_snivelling's Avatar
No_snivelling
Could be a bad switch or it could be that you are measuring phantom voltage and you may need a new battery.
Try this. Get yourself a 12 volt headlight bulb and wire it directly to the battery. Does it light up full brilliance? What happens to battery voltage when bulb is lit?
Old Jul 26, 2024 | 04:55 PM
koenig_roland's Avatar
koenig_roland
negativ battery wire to chassis... have had this some years ago and with a new ground strap, it was gone...
Old Jul 29, 2024 | 07:18 AM
0luke1's Avatar
0luke1
Thank you. The battery is fine. Ground strap is about 1 year old.
While I was sitting in it with the key turned all the way to the right, the normal instrument lights came on, so I twisted the key to start and the car started. It’s at Autobahn Auto in Sea Girt NJ. Know more today.
Old Aug 3, 2024 | 08:41 AM
0luke1's Avatar
0luke1
Loose ground connection by cd changer.
