Clicking noise from Fuse box
Hi
Today I removed the fuse box and unplug all the plugs underneath the central electric panel.
To add some wiring for the speedo meter signal after the C4 to C2 conversion.
When I placed everything back, I turn the key to position one and I hear clicking noise from one of the replay.
And car can't start just kept cranking, seems lack of fuel or ignition.
So I waited for about an hour then return to the car, turn the ignition on.
No clicking noise from the relay.
And the car starts then stalled.
Then restart again, then car starts normally and drives.
My question is, is there a explanation to this?
I am just afraid it happens again.
Does the DME suffer to disorientation?
The car behaves normal after I left the car sat for about an hour later.
Makes me wonder what is the mechanism inside the DME relay now.
