Oscillating ventilation sound
Hi all,
I experience an oscillating ventilation sound. Every couple seconds pitch goes up, followed by going down shortly after. It stops if I put temp control all the way up or down.
AC switched off. AC control unit recently serviced.
I'd imagine it has to do with the cold / hot air mixing, faulty temp sensor or actuator?
if its one of the flappers you can open the trunk remove the plastic panel right at the cowl and watch the 5 motors. they shouldn't oscillate. if they are, its likely the motor over the temp sensor.
mzjt964 (05-15-2024)
0luke1 (07-16-2024)
