Can't remove chain housing?
I'm in the middle of a reseal and having trouble getting the cam housings off. Seems to get hung up here at this point and won't come off further. What am I missing?
It's not where the housing is hitting the cam. Feels like it may be related to the chain or bottom chain guide?
Does the bottom chain guide have to come out completely first? I've pulled the bolt holding it to the case.
Originally Posted by Dick964
You're welcome.
Don't forget that these guides are really single use; do not install them back even if they are not broken.
Dick964
Dick964
The more important task - I think - I to mark you relative chain and sprocket position. Otherwise you will have to redo your cam timing completely. It can be done in the car but is a bit of a pita.
I'm guessing the idea is that these plastic guides are probably rather brittle by now. If you reuse them, they may break apart in service and you've got to tear everything back apart again.
