964 Forum 1989-1994
What should a standard battery connection look like?
Old 05-02-2024 | 09:56 AM
964George's Avatar
964George
The pic you attached in the first post has the standard positive terminal on the right.
Its basically two cables joined to a single battery terminal connector.
The two cables then disappear under the fuel tank and connect directly to the bottom of the fuse box to provide switched and unswitched 12v power.
Quick Reply: What should a standard battery connection look like?
