964 Forum 1989-1994
Laser Alignment
Old Jun 15, 2004 | 04:07 AM
adewatson's Avatar
adewatson
Default Laser Alignment
My car's been in the spray shop for a little over a week following a minor altercation with a coach in May.
As a result the car is being 4 wheel laser aligned and I want to confirm the results as printed at the shop.
I have never seen a printout for this and do not know what I am looking for. Can anyone suggest how I can check the results are to factory tolerances.
I don't believe that the accident would have caused any change in the alignment but as it is paid for by someone elses insurance I want to make the most of it.
Thanks in advance.
Adrian
Old Jun 15, 2004 | 09:56 AM
DavidI's Avatar
DavidI
The print out should confirm the make, model and year of car, and show how well within tolerances the new setup is. If you want to check that the correct data is being used you could check the print out (which shows the ideal as well) against factory data.
http://forums.rennlist.com/upload/align.jpg
Old Jun 15, 2004 | 04:28 PM
adewatson's Avatar
adewatson
Thanks David,
Much apreciated.
Adrian
