hello, your freon lines run in the left hand rear tire area. there is a panel that you can remove that exposes the lines, might be more easier to get to if you remove wheel.
Any oil leak that requires dropping or removing the engine is going to be expensive - it's all labor cost. If it comes that, this is a good time to do some other things: valve adjustment, plug replacement, engine mods, etc.
