Speaking of wheel offsets and spacers...
I have just installed a set of 7 and 8 Cup 1's with 55 and 52 offsets. My previous wheels have 40 mm offsets which really filled out the fenders. The front fenders were rolled being 8 inches wide and the rears at 9 inches. I did however like the full fender look and they never rubbed. With the Cup 1's they look a bit under tired. What would the widest spacer I could run with these wheels and have them stay under the fenders?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
You can use up to 17 mm on the rear (not that I like this personally). You should not run spacers at the front.
These are the approved words. In reality you can do what you like in certain countries but I strongly do not recommend you change the wheel position past the approved limits by using spacers.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
