Cup1 / Offset Questions
Hi All
I suspect there would be an increase in weight for a Mille Miglia over OEM but is it enough to be concerned for daily driving? Is there any differences cosmetically between OEM and the Mille Miglia and is the price difference between what a used OEM Cup1 is getting on Ebay vs. a new Mille Miglia at Tire Rack worth it?
Your responses are appreciated
Bill
90C2
Bill
90C2
That appears to be a Porsche part numbers. The Mille rims do not carry any such part numbers save for the offset. The cup II (993) versions are approximately 4 lbs heavier than their OEM counterparts. I would expect a similar comparison between OEM cup 1 and Mille Miglia repro's.
Cup II Front
Mille Miglia OEM
22 lbs. (10 kg) 18 lbs. (8.2 kg)
Cup II Rear
Mille Miglia OEM
23.5 lbs. (10.7 kg) 19.5 lbs. (8.8 kg)
Jon
Cup II Front
Mille Miglia OEM
Cup II Rear
Mille Miglia OEM
Jon
