964 Forum 1989-1994
ISV, air-flow meter and idle microswitch clean
Old 09-01-2004, 06:26 AM
  #31
DaveK
DaveK's Avatar
No sealant on mine.
Old 09-01-2004, 10:11 AM
  #32
DavidI
DavidI's Avatar
Thanks Dave, perfect.
Old 09-01-2004, 03:31 PM
  #33
PC2
PC2's Avatar
Originally Posted by DavidI
Peter, maybe a good reason to go one stage better and do the sensor of the AFM?.
David,
I did clean the AFM except that I did not remove the top cover to gain access to the actual sensor. The cover was held down by some sort of silicone. And since the sensor is sensitive to contamination, I didn't want to reseal it with just some off the shelf silicone. Any idea as to what type of silicone can be used?
Old 09-01-2004, 06:03 PM
  #34
DavidI
DavidI's Avatar
Dave K mentions here that it is ordinary clear sealant. I'd be tempted to give it a go and watch for the pitting that Dave indicates shows the sensor may need replacing.
Old 09-01-2004, 07:48 PM
  #35
warmfuzzies
warmfuzzies's Avatar
RTV ordinary bathroom sealant.
'Swat I used on mine.
kevin
Old 09-02-2004, 01:41 AM
  #36
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Most RTV silicone is not compatible with your oxygen sensor and will severely shorten its life. Be 100% positive that the sealant you use says "oxygen sensor safe" somewhere on its labeling.
Quick Reply: ISV, air-flow meter and idle microswitch clean
