Where can I buy a small tube of Graphite Grease in the US?
I'm trying to lubricate my cab top, and per Adrian's book graphite grease is recommended. I've tried Sears, Home Depot, and R&S Strauss with no luck yet. Has anyone seen this stuff for sale anywhere? I see a couple of places on the internet that sell graphite grease by the drum (!) which is certainly not what I need.
I was trying to lube the top a little as preventative maintence, and now just yesterday one of the motors that latches to the windshield stuck 2 times before finally opening properly on the third try....it's probably ready for some grease! Also, how much grease do I apply- do I just use my fingers?
Thanks-
Andrew
Thanks-
Andrew
Pep Boys is right across the street from R&S- was running last yesterday so I didn't have a chance to check. Will do tonight!
Do you simply apply a little with your fingers around the joints of the covertible top?
-Andrew
-Andrew
Burgled
I did it with the top down and left it in the sun for an hour or so hopeing it would melt in a bit. Dont know if it helped or not. Those flex joints are really tight together. Maybe someone else has a secrete way to do it. Sure would like to know myself!
