964 Forum 1989-1994
bleeding the PDAS using the Hammer... - piece of cake!
Old 05-21-2004, 02:43 AM
garrett376
garrett376's Avatar
Exclamation bleeding the PDAS using the Hammer... - piece of cake!
Tonight I completed my bleeding procedure by bleeding the locks - the longitudinal and lateral locks of the PDAS system using the Hammer. I thought I'd share the procedure if anyone was interested!!! It's really easy - as long as you've got a Hammer, of course!
Here's the mythical device (bigger than I thought!)...
Old 05-21-2004, 02:44 AM
garrett376
garrett376's Avatar
getting it fired up...
Old 05-21-2004, 02:45 AM
garrett376
garrett376's Avatar
Here it shows the cord going to the diagnostic port on the passenger side...
Old 05-21-2004, 02:48 AM
garrett376
garrett376's Avatar
I hooked up my new pressure bleeder (LOVE IT!), pressurized to 20psi after pinching off the overflow line, then fired up the Hammer.
Here's the lateral lock by the way. (sorry for the poor focus)....
Old 05-21-2004, 02:49 AM
garrett376
garrett376's Avatar
oops, my posting isn't going so well...here's the lateral lock:
Old 05-21-2004, 02:51 AM
garrett376
garrett376's Avatar
and the longitudinal lock ready to be bled (that's a 7mm bleeder nut)...
Old 05-21-2004, 02:54 AM
garrett376
garrett376's Avatar
Ok, here's after the Hammer gets started up...
Old 05-21-2004, 02:55 AM
garrett376
garrett376's Avatar
here the Hammer is downloading my car's info stored in the various systems...
Old 05-21-2004, 02:57 AM
garrett376
garrett376's Avatar
Here's where you can see the various systems - notice the # sign before my Heater System - there were 6 error codes!!!! I am not sure why - maybe from the previous owner, as everything that had an error worked fine. So I cleared the error codes - we'll have to see if they come back!
Old 05-21-2004, 03:00 AM
garrett376
garrett376's Avatar
After selecting the PDAS system, now I select the Drive Links menu (I had no error codes for the PDAS that were stored)...
Old 05-21-2004, 03:02 AM
garrett376
garrett376's Avatar
Now choose the Bleed selection...
Old 05-21-2004, 03:04 AM
garrett376
garrett376's Avatar
The Hammer basically walks you through the process from here on out - that's what makes it so simple; just read the menus and push the buttons!
Here is where I open the bleeder valve on one of the locks...
Old 05-21-2004, 03:08 AM
garrett376
garrett376's Avatar
push 1 to bleed (to make the solenoid shoot out fluid), then when the fluid comes out blue (remember I started with yellow fluid, and bled each lock until the ATE blue fluid) - press 3 to stop the pulsing...
Old 05-21-2004, 03:10 AM
garrett376
garrett376's Avatar
After bleeding, the Hammer will decrease the pressure in the system after my command!
Old 05-21-2004, 03:12 AM
garrett376
garrett376's Avatar
This screen appears to let you know the locks are unlocked
Quick Reply: bleeding the PDAS using the Hammer... - piece of cake!
