Bi-LED Projector Headlight Options
I’m happy enough with the Rennline lights I put in my 76 that for the cost savings of them I’d probably use them in my 964s too. They tend to be half the price to a third of the price from many other options I’ve seen posted here.
I haven't seen those before, but I do know that the Hella bixenon projectors are well regarded and so LED ones might be pretty decent too.
The install instructions do require cutting out the back of the headlight bucket, they are found here: https://static1.squarespace.com/stat...ht+fitment.pdf
Since you already have H4-fittings in your car, you can easily reuse them with LEDs like Osram Nigh Breaker H4-LED or Philips Ultinon Pro6000 H4-LED – The only challenges are that they are not street-legal for Porsches (yet) but from what I hear from friends do fit and work plus that they seem to not be available globally.
Personally, I stay with Osram Night Breaker 200 H4 (non-LED) (or Philips RacingVision GT200 H4 (non-LED)); the most important aspect is to have the modification that leverages a relays to not run all power for the H4 lights through the steering column switch (e.g., https://rennlist.com/forums/964-foru...r-964-a.html); that already makes a huge difference as higher voltage reaches the lights, due to this optimized setup.
Neil
mby (06-06-2023)
I went with the 9Elevenheadlights which are very expensive but he has come out with some original designs.
Mine here with the daytime running lights on each side of the beam.
Don
Don
