964 Forum 1989-1994
New thread: engine building pics
Old May 17, 2004 | 06:34 AM
Christer's Avatar
Christer
Default New thread: engine building pics
torquing thru bolts....
File Type: jpg
Old May 17, 2004 | 12:34 PM
Jeff Curtis's Avatar
Jeff Curtis
Oh the memories.
You have nice RODS!! ...on the engine, that is.
Old May 17, 2004 | 05:46 PM
Christer's Avatar
Christer
Hi Jeff
Thanks! (I think)
The only thingis that the rods came with a 22mm gudgeon pin and we need 23mm, but that is a minor setback as they have some in stock and we will get Carillo to replace. Patience is a virtue...
Old May 17, 2004 | 05:59 PM
warmfuzzies's Avatar
warmfuzzies
Hmm,
You've more patience than I Christer, I take my hat off to you for that.
But do you know the end of the rhyme?
Kevin
Old May 17, 2004 | 06:21 PM
Christer's Avatar
Christer
Actually no I don't....and I haven't got time to look it up now. Do I want to know?
Old May 17, 2004 | 06:24 PM
robmug's Avatar
robmug
...but virtue can hurt you
Old May 17, 2004 | 06:25 PM
warmfuzzies
patience is a virtue
find it if you can,
seldom in a woman
and never in a man..
kevin....font of all things bloody useless.
Old May 18, 2004 | 04:55 AM
pncarrerars's Avatar
pncarrerars
But the block hasn't even been cleaned yet, look at the oil pipe bottom right!!
Old May 19, 2004 | 07:56 AM
darth's Avatar
darth
Christer
I don't see the seals nor the groove to accept a seal in you picture above of the block. I was expecting to see the same base seals as Bill V. illustrated in your other post.
Just Wondering
Bill
90C2
Old May 19, 2004 | 08:47 AM
Christer's Avatar
Christer
Bill
The groove you mention are usually used with the 109mm p&c's because you have to machine the case to make them fit anyway. With these slipfits this is not necessary according to 9M.
Old May 19, 2004 | 10:30 AM
darth's Avatar
darth
Christer
So in other words - the groove I seen machined in your cylinders is for the seal.
...bill
90C2
Old May 19, 2004 | 10:38 AM
Christer's Avatar
Christer
It would seem we have reached a point of misunderstanding. 9M told me that they do not machine the case for base seals due to the fact that the pistons are 107mm slipfits. Beyond that, I would have to ask more questions.
Old May 19, 2004 | 10:39 AM
Christer's Avatar
Christer
another thought, if we are talking about cylinder head seals then yes these will be installed....
Old May 19, 2004 | 11:19 AM
Jeff Curtis
The groove comes already in the cylinders provided from the factory, just as it would be on the "regular" 3.6 cylinders. The picture that Bill V. posted is of a factory setup with the seal blown.
The only way I can figure this happened is either a broken head stud, and the seal bloew out as a direct consequence or the installation was shoddy and they had a pinched seal in the first place...but this is just guessing, as I find it hard to believe that a seal made it all the way through, and OUT of the mating surface.
IMHO, Christer's engine should be fine WITHOUT the "custom" modification used for the case spigots and the cylinder flanges...the factory grooves located directly at the bottom of the cylinders should be sufficient...as long as the mating surfaces have been matched with minor machining.
The heads/cylinders must sit PERFECTLY flat against the case spigots and the cam housings...this is accomplished by minor machining during a rebuild process, usually referred to as "decking".
Sorry, just had to spew out my daily helping of engine rebuild jargon.
Old May 19, 2004 | 11:45 AM
Bill Verburg's Avatar
Bill Verburg
Jeff, that pic was a 3.8 w/ the 109mm spigotts using the stock(goove in the cyl base only) method of base sealing. All of the seals were blown out. The 993RS has a factory milled groove in the case wall to match the one in the spigott base. Stock seal is a 102x2mm o-ring, 993RS uses a 110.72x3.53 for the 109mm spigotts.
The engine was correctly assembled, w/ the correct seals but w/o the case grooove. That was the issue. It is now quite happy.
