Rennline Valve cover leak issue
Hi
My Rennline lower valve has been leaking badly recently.
We use Victor Reinz gasket, but it seems gasket groove is deeper than the the gasket itself.
Had the feeling that the gasket is not compressed enough while tightening the bolts.
I read from reenlist that some others skimming a the surface of the valve cover to make it shallower.
Does anyone know how much is the depth of the stock valve cover groove or how much to skim it off from the valve cover?
Originally Posted by parkertseng
Hi
Did you clean the crud off the cam tower before installing. Dirt can get trapped and cause them to leak. This is a common problem I find.
The factory spec book calls out 7 ft pounds or 9.7nm if that helps. You should be able to feel when they snug up which will be about correct when checked with the torque wrench.
