Tie Rods Replacement - Feedback on Prekom?
I looked for the replacement part online and found Prekom parts. The endlink that goes directly to the direction cilindres has ball joint vs the OEM joint, and looks sturdier from my side.
Anyone has some feedback about these tie rods? http://prekom.si/porsche-parts/porsc.../tie-rod-ends/
https://www.prekom-usa.com/product/9...-rod-assembly/
The conical end is different on the 993 uprights so you need 993 tie rod ends. No issues using these on the c4 with all its extra bits either. You’ll need 993 steering rack boots too.
Prekom, if you’re listening, message me for my advertising kick-back payment
So, in order to install those on my 964 C4 1990, I'll be needn't 2x 993 RS tie rods, 2x 993 rack boots? Anything else? Because I think that it would be an interesting upgrade
I'll have to keep the extra 5mm longer steering stops for 17" wheels?
This is one approach on a C2, though there are some alternative options and some things left out-
https://rennlist.com/forums/964-foru...ghts-long.html
The lower strut hardware is all different.
The 993 ball joint stud on the control arm is different.
You'll need 993 front calipers/rotors and 993 C2 rear calipers, 993 front wheel speed sensors, front bearings.
The 993 inner tie rods need cut down if you use 964 longitudinals.
Steering stops are as-needed. Depending on the wheel/tire/offset/alignment, they may not be required. It's a safe bet to use them but you lose a touch of turning radius.
C4 adds one extra requirement- the front axles need modified for the dust cover lip on the outer end
https://rennlist.com/forums/964-foru...l#post18348246
All up I'm done for less than 150 bucks.
I'll try to get the 964 ball joint option and install the spacers shown to get the upgrade & 17" in place at the same time. Thanks!!
Mine is a 1990, so I will install the spacers.
