Smoke!! --- HELP!!!
Help!!!
I just added a quart of oil to top off my car. Also checked the guage and dipstick and oil level is fine. Then I noticed that my car spitting out blue smoke at idle. Same amount as in the white condensation you get on a cold morning. I couldn'thave overfilled or dripped oil somewhere? Any idea? Also, the plastic piece connecting my rear blower into the engine fan is torn off. Will this cause heating problem? thanks, anthony |
This morning, everything seemed fine. Pretty much no smoking but once in a while I get a puff when looking in the rear view mirror sitting at a traffic light.
You have a boxer engine. Every cold start ther could come some smaal amount of smoke, because tho oil stays in the cylinders, and will not drop back as a normal non boxer engine. Smoke should be gone after a few seconds.
Thanks Arjan. But my car doesn't smoke on startup besides condensation. I checked that many times.
I smokes when the engine is warmed up. Today, I saw only the smoking once. I will pull and inspect the plugs this weekend and continue to keep an eye on this. ---- anthony |
