cleaning exterior 993 92l fuel tank
Hi all!
I bough a used 993 RS 92l fuel tank, but the plastic has white markings on it, which can't be cleaned off. I don't really want to use a Bunsen Burner on something as expensive and important as this. If you do have evidence that this is the best and safest way, then I may give it a shot, but prefer other options in the meantime![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_8913_7a1430eca5ab1cbf46b10bc8dbacac72934926fa.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_7916_643a07fef53165df994e0d3b2e95616105820a6c.jpg)
Maybe this helps:
https://smile.amazon.de/dp/B0024X2L6...lig_dp_it&th=1
Seems to work on plastic parts in the engine bay according to PFF members
Regards
Uli
Regards
Uli
Undutched (05-07-2022)
Wow that thing is huge.
I have had good luck using ceramic coatings on plastic to bring the color back to black.
Maybe this helps:
Regards
Uli
Regards
Uli
Ill put them both next to the each other. Its not placed 100%, since I still need to place the pump and new lines as well.
