964 Forum 1989-1994
Window switch replacement?
Old Feb 15, 2022 | 10:38 AM
964TURBOCHAS's Avatar
964TURBOCHAS
Default Window switch replacement?
When replacing a switch do you need to pull the door card or just pop the switch out and swap?
thx
chas
Old Feb 15, 2022 | 10:41 AM
delanobe's Avatar
delanobe
You can pop the switch out, very easy.
Old Feb 15, 2022 | 10:54 AM
964TURBOCHAS
thank you
Old Feb 15, 2022 | 10:59 AM
jpoint's Avatar
jpoint
If you don't already have a new switch the old one can be "rebuilt" pretty easily. If you open the old switch you'll find a pair of contacts - one for up - one for down. The contacts are the same and have 2 sides each. If you reverse the contacts you'll have a fresh contact on each side and the switch will work again (unless the switch is otherwise broken).
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
