C2 Brake Vacuum Booster issue
I am trying to solve an isue with my '90 C2 vacuum booster that is getting worse. I had the booster rebuild a few years ago so I don't think (but not sure) it's the booster. When braking, I lose boost at random intervals and the brakes suddenly go hard. After a few minutes, everything is back to "normal" but I fear I am not sure any more what normal feels like. I do get a high pitch whistle when coasting so I think I may have a vacuum leak somewhere between the manifold and the booster. I get marginal vacuum at the manifold but have not measure at the booster yet - it's cold in Chicago at the moment.
So my question, does anyone have a schematic of the vacuum line from the manifold to the booster in the front. Is it all flex line and where are possible points of failure?
Thanks!
Thanks!
If you look on DCautocatalog you can pull up the parts schematic , as prior poster mentioned I believe that is a hard plastic tube running through the tunnel that meets two rubber hose lengths on each end that have junctions to the engine and the booster , likely one of the junctions or the line itself has a crack...Bert
Thank you. Just order the parts and as soon as it gets a little warmer in the garage I'll take a look. I see more and more fatigue failures but that's to be expected- and we haven't even talked about the car yet. 😊
