Speed bleeder for c4 diff lock install question
I decided to purchase a couple of M6x1 speed bleeder nipples for the two diff locks on my 964 c4. My question for those who might know: do I need to depressurize the system before I swap out the nipples? I know when I did my "borrow your teenager to operate the switch" method they would initially squirt out a very small amount of fluid, and then not much pressure/fluid beyond this.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
The small high press. 'squirt' volume is all that is required to move the piston and spindle. No need to depressurise - just a lengthy bleed when done. Someone else may chime in with other useful info.
Looking to do this soon as well. I believe @Goughary knows this process and is aware about the new seals needed for the bleeders.
964Luftballoon (01-18-2022)
