Backdating 964 timing chain boxes
While not aligned in profession with you guys, my professional career is 25+ years in data. I'd love to map a chart or three on the aluminum and magnesium alloys used in the two chain boxes in question here combined with academic research to see at what point one would be more beneficial over the other in terms of resistances and other variables. May just prove your points @cobalt ....which, naturally would warrant an afternoon in the passenger seat of your 3.6T.
I am not familiar with the Journal of Materials science but there are so many institutions. I dealt primarily with AMS, ASTM, MIL, and a few others. You might look into MIL (AMS) M-3171 it covers the DOW conversion treatments my grandfather helped design back in the 30's. My grandfathers research is usually part of many of these articles but he doesn't get any credit. I have his hand written journals from the 30's to the 50's and he tested every type of alloy and coating for magnesium and aluminum. He turned over all of his R&D to the federal government in 1940's which helped reduce the national scrap rate by 40% for both aluminum and magnesium. I have a letter to him from Igor Sikorsky, DOW and the federal government stating that it is possible he helped save the country from losing WWII as his R&D helped to build aeroplanes, boats etc that if he didn't help reduce scrap would have lead to a shortage of weaponry. Ironically in the 50's after he retired many took his notes and added to them taking full credit for his efforts. I plan to one day turn everything over to the American Foundrymen's society. I am sure it will make for interesting controversy over who discovered what.
I have a lab that did all my spectrochemical analysis and would be easy enough to have tested. Every part I made had to be tested for ultimate tensile, hardness and chemical composition at a min. Even the raw material had to be tested prior to casting parts and checked against the smelters report. There were times I had to add elements to the material to achieve the strength I needed.
The problem I have had with the few parts that do have alloy designation is they use a different classification for alloys than I am accustomed to. Porsche doesn't discuss such things unfortunately. This is why I am thinking these boxes are Almag 35. It would have been much easier to cast and less susceptible to corrosion. It will turn black naturally over time due to the high mag content. I don't know what coatings they used but they did not follow the MIL specs I had to work to and the chemical conversions my grandfather basically invented back in the 30's. I know things like the Italian made Cup I's use a similar alloy to A356.0T6 aluminum but the SM versions use an alloy I don't have a match for. There are no markings on the valve covers or timing chain covers. The aluminum and magnesium valve covers are made from the same tooling as mag and aluminum shrink equally.
I used to make parts for my friend Joe who owned the Targa Florio winning Alfa Typo 33. He actually used to joke and say there are only two foundries in the world he would trust making his mag parts and I was one the other was in Marinello but I was quicker, cheaper and put up with his BS. He used to bring me originals and say make these. I would tell him he needed tooling but wouldn't pay for it but after making multiples, chopping them up and adding material where needed to compensate for shrinkage he spent about the same. I made several parts for his and other similar models for his friends and cars he was restoring. Just about anything you see in yellow/gold I made. These parts were still in good condition even after all these years and when I made the replacements back in the 90's the originals were still for the most part in good condition minus corrosion from exposure to the elements. If he refinished them years earlier they wouldn't have needed to be replaced.
It is amazing that some cars of the day used mag for coolant lines which was not a smart move.
I have been fortunate enough to live a very colorful life. Seems my decision to settle on 964's was one of the better ones I made.
But...
On another note...and back to the original original question...Sort of...
Does anyone have a stack of Porsche parts around that can shoot pics of the old boxes, the 964 boxes, and the 993 boxes so we can see pics and the differences btw them?
That would bring this back down to reality for us lay people with our pea sized brains who just want to turn wrenches and be greasy...you know, the world of duct tape and cotter pins...
I can see if I can access an earlier aluminum box but everything changed from the old style ramps, chain tensioners and other bits. Seems to me we would be going in the wrong direction. IMO the 964 & 993 parts are a better design irrespective of material choice.
The timing boxes and chain ramps for the original 901 engine design lasted all the way through the 3.2 with minimal changes and it worked well. Then suddenly they changed it to the 964/993 design. There are lots of fiddily bits in the early timing boxes that aren't in the 964/993 engines. It appears to be a cheaper way of doing it, and cheaper to build.
Just my $.02 on this.
Clay
Clay
Magnesium usually costs considerably more than aluminum to manufacture. I cast both and can assure you the mag choice was made for one primary reason and that is noise. Porsche could never leave well enough alone and are always changing things. Porsche was on a kick to reduce noise and the 964 was a boringly quiet over muffled car stock which IMO also contributed to lower sales. Even the 993 got hydraulic lifters which quited things down even more. We all modify our exhausts to bring back some rumble. Think about it you have a more complicated casting now made in magnesium and all the rubber grommets, gaskets, studs nuts and caps vs an aluminum housing and paper gasket. I don't think it was a cheaper approach from my perspective.
Give me a 964/993 engine anyday over anything prior. If you don't like your engine i can source a nice 3.2 we can swap even trade.
I prefer rebuilding them over the earlier versions, The tensioner design alone IMO are worth the change. I don't think the bean counters were counting as Porsche spent a fortune changing these cars and were 85% different than the G bodies. The investment and low sales nearly bankrupted the company. I admit corners were cut but by 92 they fixed those mistakes and continued on. IMO the bean counters kicked in when they brought in a 3rd party to transform their manufacturing processes and just in time manufacturing for the 993 and boxster.I hope you figure out your issues. I have not had these same experiences and that doesn't mean they can't warp although my knowledge of the material tells me if they do it is more likely from improper installation than the material itself. If you feel aluminum is a better option than best luck. I will take a mag casting over aluminum any day depending on application IMO it is the strongest lightest metal and is greatly misunderstood.
When I dug into the area, I noticed it wasn't was was indicated on my PPI notes at all, which read "sweating timing chain box and cover, needs new gaskets/reseating". The PPI notes is why I purchased the gasket kit and the 1/4" torque wrench in inch pounds to do the job.
What I discovered was the valve cover and oval crank case vent (top rear of the block, as you know) to be the culprit, leaking down onto the chain box and cover. Now, while in there I verified the torque on both timing chain covers, which was a tad low on some nuts.
You can see some oil residue, but I didn't see any leaks coming from either timing chain box, photos from the job this weekend:
If the box/cover was indeed leaking, I'd assume there would be a much bigger mess on the heat exchange/header area.
You can see here where the crankcase breather and valve cover leak from above is pretty evident. I removed and set aside this bracket...which appears to be from the original exhaust. (Side note, whoever installed the Fabspeed RSR setup on this car needs to be smacked. Terrible work...which damaged several pieces and took me an extra hour and a half to correct)
The vent hose and gaskets at the top of the engine can make messes and is something everyone should consider looking into at one point. While doing that it is most likely time to consider changing old fuel lines. Once you start to move them they become suspect.
I absolutely love the engine. I just want to fix the oil leak. I need to get my E-34 BMW off my lift so I can pull the engine/transmission from my 914 and fix the leak. I bought a new timing box from Porsche, and I am waiting on all the fiddily bits needed to install it. Supply chain issues. :-(
Honestly, this was asked just to see if anyone had done it in response to the warped chain box issue. I am a retired mechanic turned IT guy. I am not a engineer or a metallurgist. So I took your advise and am going to replace everything on the right front corner, including the rocker shaft seals. Yea, I know, shotgun diagnosis. But pulling that engine/transmission combo out of a 914 chassis is a really big undertaking, and I don't want to do it again.
Thanks for the Education everyone. I have learned more about magnesium metallurgy than I ever thought I would.
Clay
Clay
See what happens when you get Covid and your booster at the same time.
Cooped up inside makes me a little punchy.Best luck I hope this fixes your problems at least for a few seasons. A 3.6 in a 914 chassis is a heck of a weapon.
