Engine oil...
Engine oil...
I have 3L of Catrol Edge 10W60 from my old E92 M3 and I was going to stick with this but then started reading about engine oil... obviously I am now rather confused about the subject.
I am tempted to try Millers Nanodrive CFS N+ 10W60 based on what I have read so far. Any thoughts on this oil and the weight? Opie Oils in the UK seem to recommend 5W40 for these cars but many seem to be using at least 10W50. I am located in Prague, Czech Republic and the car is mostly going to be used in better weather.
Thoughts?
Thoughts?
I have no idea what the ZDDP level is in the Millers oil I am considering. I did read something somewhere that seemed to indicate that it can be too high as well and that it's not necessarily the case that a higher ZDDP level equals less wear. Certainly higher than the Porsche classic oil would be a good idea though based on what I have read thus far!
I've been recommend by my engine builder and I'm sure others will chime in on this contentious subject. Penngrade (formerly known as Brad Penn) 20W-50 is what I use.
darylbowden (12-16-2021)
That brand seems to be quite popular but I'm not seeing it in Europe.
The following 2 users liked this post by revolve40:
964Luftballoon (12-14-2021),
velocitylover (12-15-2021)
Not having looked into this in the past I am interested in what people are choosing and why they might go for a 20W50 instead of a 10W60, for example. I guess 20W instead of 10W would be better for the engine on cold starts in colder climates? I've next to no idea other than what I have read in the last day or so.
My question wasn't bait either - it was just a question, with no reason for any arguments and none in evidence thus far. Just people sharing their opinions and advice in a friendly and helpful manner. Mostly.
Thanks for your input though.
Well, I can see my attempt at humour has been an abysmal failure.
But asking about oil, is kind of like asking who has the best hockey or baseball team. It invokes strong feelings and often results in heated debates. This is why others in this thread have referred to it as a "hot" or "contentious" topic.
Anyway I had no idea you did not have an owner's manual. Here is an excerpt from the 964 manual that may be useful. Cheers!
Tom
To Moderator, if this violates copywrite policy then please delete and accept my apology.
Tom
Tom
Tom
I appreciate you taking the time to post that excerpt - I wonder if the recommendation has, or would have, changed over time as oil technology has (presumably) changed. Maybe it hasn't really changed as much as marketing would make us think? I've no idea. The recommendations in the manual are interesting. Based on my location I think 10W50 should be fine.
I guess also oil technology has come a long way since the handbook was written - not from a view of not relevant, but more the types/grades of oil that are now able to be 'modified' for types of use and engine mileage/hours (e.g. track vs road vs classic etc).
Here is a brief history of API oil categories and classifications.
https://www.api.org/products-and-ser...s#tab-gasoline
