Motul 300 + G50 = ?
I recently had the transmission oil changed, using Motul 300. Two days later at a track event I experienced problems shifting into third. There had been some grinding at previous events, but nothing as bad as this. I'm pretty confident there is something wrong with the transmission, but I was wondering if the oil may have exacerbated the existing problems, and whether it's a good choice for the next fluid change, probably when I have the transmission fixed in the not too distant future
Thanks for any info!
You may want to look at your motor mounts to see if they need to be replaced. Bad mounts could cause problems shifting. Mine made the second to third shift a problem.
