I was wondering whether anyone could shed some light on where the cables off the positive post on the 964 battery go? I am in the process of wiring up a 6 pole kill switch and while I understand the concept and how to wiring it up correctly, I am really wanting to know where all the positive cables go (the 964 wiring diagrams while not terrible to interpret they are far from straight forward).
There appears to be 2 cables crimped to the terminal that connects to the battery post (One 0 AWG cable and One cable with 3x 10AWG shielded) - these cables run across the floor of the frunk (0 gauge appears to go to central electrics) (first photo). Additionally, there are 2x 10awg cables crimped together with a 1/4" terminal ring that goes into the body harness (second photo).
Any assistance on the matter and identification of the cables would be fantastic!
Cheers, Shielded Cable with 3x 10AWG Cables (left) and 1x 0AWG cable (right) with terminal cut away in background. Body positive cables (2x 10AWG) with battery terminal held to show mounting position.
Cheers,
Check out the wiring diagram from the workshop manual, pdf versions can be found online.
Below is a snippet from page 36 for the 1990 964.
It shows all the wires from your pics and where they go to.
The 35 gauge (0AWG) black wire splits out later to feed the central electric (term 30) and the ignition, but also carries on to the starter motor.
The 3x 4 gauge (10AWG) red wires feed R11 (term 15e), R41 DME and the Radio.
The 2x 4 gauge (10AWG) red wires both feed the ABS unit.
At least one of the large + wires goes in the passenger compartment near the right center of the passenger side, passengers left foot will be over that area, it then runs under the floor padding and back to the starting motor on that side of the car
