964 Forum 1989-1994
Power steering belt
Old Jul 20, 2021 | 10:02 PM
JohnK964's Avatar
JohnK964
Originally Posted by titleistaddict87
I just did this with the engine out and couldn't imagine having to do it with the engine in. Fingers crossed my belt and nuts are good!
😂I really considered dropping the engine and trans to do this job then some guy said he did it in an hour 🙄 So I went back at it and finally got it done
Old Jul 21, 2021 | 04:17 AM
joerg65's Avatar
joerg65
Job done! I replaced the missing nut from over the top by feel, then with 1/4” ratchet. I slipped the new belt down from the top then first got it around the lower pulley from below. After this I returned to the top to get the belt over the right hand portion of the upper pulley. I rotated the engine by hand and slowly guided the belt right around the upper pulley. For the moment I’ve reattached the plastic cover (repaired with JB Weld) whilst I wait for the new one to arrive. I have a G pipe so I had pretty reasonable access from below to replace the aluminium cover plate and exhaust support bracket. I didn’t remove any engine tin. Fiddly but not too difficult with the engine in.
Old Jul 21, 2021 | 10:11 AM
JohnK964's Avatar
JohnK964
I think the fact I was removing and rebuilding the pump probably had more to do with how I approached it than replacing the belt. OP Good job!
Old Jul 23, 2021 | 08:28 PM
yelcab's Avatar
yelcab
Originally Posted by JohnK964
😂... then some guy said he did it in an hour 🙄 ...
...some guy... = this guy.
Old Jul 23, 2021 | 08:30 PM
JohnK964's Avatar
JohnK964
I know you inspired me to go back out and make it work 😎
