DME Relay Questioin
DME Relay Questioin
1990 964 C-4
Was always under the impression that the car would not start without the DME relay in place. After a valve adjustment, I pulled then relay so I could get some oil circulating before starting. Car started anyway. Shut it down after 2 seconds, then plugged in the relay and started normally. SO, did the car use whatever fuel that was left in the fuel rails and injectors to Start, since the fuel pump was not working?
