Okay, you asked for it--Momo wheel installation made easy!
#76
in particular i dont understand that point:
Note: The 7004 hub is the correct part but the diameter is actually just a little big. The solution is to sand off some material from the collar halves to enlarge the opening---CAREFULLY-- so that they fit around the adapter. I used the sandpaper sheet wrapped around a coke can trick to trim it back.
what do i have to sand off? Does anyone have a pic?
#77
When i install the horn part, should i connect the cable at the backside?
