Weight info: RSA seats vs. Sparco
In an attempt to improve my 'give advice/information post' to 'receive advice/information post' ratio (currently at 1:10,000)...
I installed a Sparco EVO seat with sliders and aluminum side mounts (thanks Rob). Here are the definitive results of the subsequent weight loss:
Stock RSA seat: 49 lbs. (!)
Sparco EVO (w/sliders and side mount): 21 lbs.
For a weight savings of: 28 lbs. per seat
Unfortunately, I only had 1 Sparco seat to install, so my search for another used seat continues.
I mounted the seats as low as possible, and definitely sit lower than with the stock seat. However, I still feel very comfortable with the driving position. I will also be adding a new Momo steering wheel, and quick release device.
Overall, I'm very happy with the change, and can't wait to get out on the track with the new setup.
Erick
Erick
Congrats! Make sure you check out the driving position with your helmet on before hitting the track. I like to have about an inch of clearance between the headrest and the back of my helmet when looking straight out. Too little and you won't be able to sit all the way back without dipping your head down; too much and you'll be craning your neck up to view what's coming.
Perhaps the suggestion is common sense or borderline insulting
but it'd be a shame to realize the need for an adjustment after arriving at the track. Next, you might want to drive around the neighborhood with helmet and gloves on just to make sure everything works fine (okay, now I'm just being a wiseguy).
21 lbs is great ... I'm not sure you can get much lighter without going with the kevlar ($$$$) option. When's your first event?
Originally posted by Doug H
Are mine the RSA seats. If so, I don't think 49 pounds is correct. Those things were very light. Didn't weigh them, but they felt more like 20 pound range.
Erick
Originally posted by joey bagadonuts
Congrats! Make sure you check out the driving position with your helmet on before hitting the track.... When's your first event?
I don't have a first event scheduled... yet. I've been thinking about it though. Once I get the car running again, and have insurance back on it - in about a week - I'll be looking to make firm plans.
I can't wait!
