looking for longer front strut collars
bingo!! thanks thet is the item, thank you
may i ask have you used them?
if so in there highest position, are they as hi as the stock ones in there lowest position?
sorry, but i only want to lower the car about 3/8 on an inch
Sorry, I can't help with the specifics nor have I tried the item. Give Sol Snyderman at Perfect Power a call (proprietor, chief wrench, 911 guru) at (847) 367-8837. He should be able to answer all your questions.
Good luck!
Good luck!
